Pololu
Hello,
I was wondering if someone might be able to help me, I have bought a Pololu Dual Serial Motor Controller and am having a tough time getting my motors to even spin.
I connect it exactly as is shown in the instructions, use the example code and nothing happens. I am hoping that maybe someone here has had this problem before and might be able to shed some light onto it.
Any advise would be very helpful...
Chris
I am using the Tamiya Worm Gearbox and the motor that comes with it.
Chris
Jeff T.
1.· If it is a kit...
·· a.· are there any short circuits
·· b.· are the two chips inserted correctly
·· c.· is the capacitor installed correctly
2.· Is your power supply good?· Do you have your grounds tied together?
3.· what is the code you are using?
4.· Have you contacted Pololu?· They are very good at customer service and should be able to support you.
B
I didn't see a controller with that part # but the Pololu controllers I looked at had two possible serial inputs RS232 and TTL. You said you veiwed the signals with Hyper Terminal does this mean your signals are RS232 or are you using a level shifter. The code I saw was for a non inverted (TTL) signal. Can you post code and a description of your connections. Connecting RS232 to the TTL input·may damage the controller.
Jeff T.
The data on the scope toggles 5 volts. I have quite a few serial out projects over the years with htis setup and have no data issues; lost data, incorrect data . . .
So far as the code goes, I am not with the project at the moment. I used the sample code that came with the Parallax supplied motor controller, p/n 30052. I checked the baud rate in the serout command, confirmed with HyperTerm. The PC was never in contact with the motor controller. The PC does not send data to the controller, only the PIC. The handshake lines are not connected to the PIC or the motor controller.
So far as the connections go, serial data out on the PIC is B7, reset is B6. In the code, I pause 1 second to let the rails settle at power up, then pull the reset line low for 500ms, pause for 500ms then send out the serial commands to move motors, as described in the sample code.
I was wondering if I need to have a stepper or servo motor on the motor controller outputs or is a fan or the scope enough to see changes on the motor cotroller output.
Thanks for the quick response.
B
As you can see the config code is outside the for loop, but for some reason that line keeps getting sent out, pulsing pin 9 of the motor contoller. It's these pulses that make the motor go, not the change in the variable, speed.
I have a 9-volt battery (new, measuring 9.5v) operating the motor and a 5v supply taking care of the logic side.
I'm using PICBasic Pro. Not much different than BS1. I double checked the baud rate, parity, and converstion.
Many thanks for anything that might help get this turning.
B
Include "modedefs.bas"
speed var byte
high portb.7 'serout line
low portb.6 'reset line
pause 100
high portb.6
pause 100 'motor control start up
serout portb.7, T2400,[noparse][[/noparse]$80, 2, 2]
pause 100
here:
for speed = 0 to 127
serout portb.7, T2400,[noparse][[/noparse]$80, 0, 5, speed]
pause 20
next
for speed = 127 to 0
pause 20
next
pause 1000
goto here
Jeff T.
That was it. Thanks. I have been looking at this for days . . . . rewiring, rereading . . . . ughhh.
Many thanks.
B
