PENGUIN ROBOT Hand Controller Template is Coming Soon!
I'm developing a drop in code to enable use of
a hand held remote for any Penguin robot program.
With this software code, you can control Penguin
with the IR remote, and add in your own functions.
This is a 17-function program, and takes up only
25% EEPROM. That leaves a whopping 75%
mem for your code in the first page. It also leaves
registers 2 through 12 open on the RAM for BITs,
NIBs, BYTEs, and WORDs.
humanoido
Added functions can include motion, music, Penguinese language, sounds, compass, light level detection, IR functions, VR effects, and special routines. The code is designed specifically for Penguin robots' fast microprocessor timing clock cycles. It includes the Bit Key Translator (BKT) and will display the name of the key pressed on the remote. This code introduces a special feature. This is the External Polling IR Timing Pulse Preservation Driver (EPIR-TPPD), pronounced "eper-tipped." With EPIR-TPPD engagement, the robot will do functions while running the remote. This means you can have sensors running, and see key presses on the remote, all in the same loop! Everything is automatic. You only need to press keys!
humanoido
you are a programing god! keep up the awesome work!!!!!
scott
