PropRPM
I notice the propRPM only has one voltage regulator. Is it a 3V reg?
If you weren't going to use a keyboard, mouse, or anything that requires· 5V, can you power a Propeller·breadboard with only a 3V reg?
What are the values of the 2 electrolyic caps? (Are those electrolytic caps the input & output caps of the 3.3V reg?)
Tony
Post Edited (TonyA) : 9/16/2007 1:24:55 PM GMT
Tony
I just took a look at the schematic for the propRPM, so I see those caps (electrolytic) are the 3V reg input & output caps.
(Referring to the RPM schem describing the electrolytic caps of the 3V reg) I have never seen this before, what is "100 u / 16" ?
Does that literally mean divide 100 microfarads by 16? Or is it just a 100 uf cap?
Generally 100 uF will suffice for both.
It will even work without any, if you have connected the recommended 100 nF to each chip.
Edit: I just see your posting: "16" means "max 16 Volts".
Have a look into the host of basic electronic tutorials available!
Post Edited (deSilva) : 9/16/2007 1:43:18 PM GMT
Would that power circuit (the one shown on the propRPM schematic) also work with a 9V battery?
Thanks again.
(Why would I need to read the boring tutorial when I have you?) <--joking
Post Edited (TonyA) : 9/16/2007 1:50:11 PM GMT
You see, due to the construction of that kind of regulators, they draw the same current from the battery as is needed by the circuit. Say you need 250mA. The power not used is transformed ("dissipated") into heat within the regulator.
In that case it is 5.7V * 250 mA = nearly 1.5 W.
Which is much! It works but I should recommend an additional small heat sink.
Ok, I see.
Thanks again. I appreciate it.
FYI: Since the IR module outputs a data signal at 5v, I used a 4.7k resistor between the IR_Out and the Propeller_IN pin. It is working rock-solid!
