Using the Memory Stick Datalogger
Hi All,
I'm testing the memory stick datalogger on my Board of Education kit and I'm getting an unexpected result in the Debug Terminal.
Here is what I get:
Memory Stick Datalogger Test V1.0
Synchronizing...
Checking for USB Flash drive...
Drive
Ready...
Random Number (Seed) = 7618
Error reading the seed file -- Halting execution!
When I connect the thumb drive to my PC and check it out I see that the expected "SEEDFILE.TXT" isn't there. Instead it is "SEEDFILE" but missing the extension.
Anyone ever see this before?
Lance
Here is what I get:
Synchronizing...
Drive
Lance
Lance
Just opened my thumb drive, and checked it out. won't be able to test it till until Monday.
Just read the Doc. though. Are you connecting your thumb drive directly into your computer or are you connecting thru a hub ?
Rob7
Directly. But I think the issue is when it's connected to the STAMP, not the PC.
Lance
In the documentation there is a section that covers possible corruption of the drive file system and how to correct it using chkdsk. Please read that section and follow the directions to see if this solves your problem. Take care.
The main thing I wanted to say and maybe get some feedback from anyone who has had a similar experience to me is about the memory stick itself. I had read on other posts that some thumb drives would not work with the datalogger. So whenever I came across a drive that would not work right I put it down to the fact that this was a bad thumb drive to use with the logger and discarded it from the project.
Recently I decided to go back to a couple of these "bad" memory sticks and instead of formatting from explorer like I would normally do I formatted from Computer Management which gave me more options on the way the stick is formatted. I was surprised to find the "bad" sticks would now work fine.
I have not tried enough memory sticks and don't know enough about formatting to know if this is a "cure all" but wondered if anyone else had an answer or seen the same thing.
Jeff T.
