Using a microcontroller as a I/O controller?
I've been designing a Motorola 68000-based microcontroller for several months now. This was supposed to be a fun and educational project for me. The only thing stopping me from completing the design is the I/O interface. Simply put, there is no good, low component, way to add addressable bi-directional I/O pins to a microprocessor. At least that's been my thinking...
...Until today...
I just had a thought that I could use a microcontroller as an addressable I/O controller. Looking at the SX48BD-G, I could use four I/O pins for the address, 16 pins to the 68000's data bus and the other 16 pins to an I/O header. I would only need a small amount of RAM on the controller(s) for a pin direction control register. Other than that, the microcontroller's software would just check the the address pins, which would act as a chip select, and if selected, transfer data between the data bus and I/O header.
Is this doable? Is there a better way?
Post Edited (MarkS) : 9/15/2007 2:23:06 PM GMT
...Until today...
There used to be plenty of I/O controllers available for bus-based systems. The 82C55 was a very popular chip for this and may still be available. My recommendation would be to find such a chip and use it. You'll spare yourself a lot of agony over trying to shoehorn an SX into an app for which it's ill-suited.
It works great from my PC, using the parallel port for bidirectional synchronous nybble-wide communication like that old laplink protocol, to read and write hard disk sectors.
I don't know the device interface requirements of the 68000 but why not use an SX for this? I'd say why not go for it, but work through the design really carefully, because those IO pins have a way of getting used up really fast as you plan out all the necessary control bits that will be needed.
If you're interested, I'll post what I've done in the projects area.
David
