I2C temperature chip 8DIP?
Fellow Stampers;
I am looking for and I2C temperature chip in a DIP package. The closest I have found is the TMP100 from TI in SOT-23-6 package. I have a DS1602, but have an application where I am short of I/O pins, and I already am using I2C to a memory chip 24LC32A. So if I could find a I2C temperature chip with DIP, I could use it on the same I2C lines (bus).
If you are aware of any such chip and where I could get it...that would be great.
Thanks, John
Thanks, John
- Rick
John
Keep in mind that I2C is a trademark of PHILIPS so it also goes by a more generic name of "2-wire".
PIN SYMBOL DESCRIPTION
1 SDA Data Input/Output Pin for 2-Wire Serial Communication Port. Open-Drain.
2 SCL Clock Input Pin for 2-Wire Serial Communication Port.
When you see SDA and SCL it's a giveaway that it's I2C.
Hope that helps.
There's nothing like a new idea and a warm soldering iron.
Nuts and Volts 111
I checked the usual suspects for the DS1621 and only Digi-Key had them in stock. Didn't look for the 1631.
- Rick
The 1621 is 2 wire and supports I2C (according to the Nuts and Volts 111 article). So if I use the 1621 ( available from Digi-Key in DIP package) I will be able to use the I2CIN/OUT commands
For now, it looks like I'll be ordering a $1621 from digikey for $4.61
John
ps. we should have a list at the Parallax site listing all known I2C chips that will work(have been tested) with stamps. I have come across:
1. 1621 temperature sensor
2. 24lc32 memory/storage chips of various sizes
3. 8591 a/d, d/a
4. 8574 i/o expander..that didn't work. could replace with mcp23016
