Just after boot ?
I have not programmed a propeller yet so consider my lack of experience.
After boot up the four pins used for the process, serial and i2c, are no longer driven by the boot code?
If correct then i have to have a method to run the serial port and the i2c port in my application (object?) to take over those pins if i want those function which i do?
If correct is there an object that handles both that i can past into my application so all works after boot as before boot?
cheers,
rich
cheers,
rich
Paul Baker
