RF Communications
Hello all,
I am using Parallax's 433 RF modules in a project for one direction communication and it works well. I would like to create a new project that has two way communication between two pairs of BS2 modules (or four communication points). Are there any options I should look at for this kind of project?
Thanks!
Carlos Ferguson
Thanks!
Carlos Ferguson
Dave
Dave Andreae
Parallax Tech Support·
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Carlos
Yes you would. You could have one controller that both talked to, but not two controllers each controlling a different bot. The problem is of course that if controller A is using 433mHz to talk to robot A, robot B and controller B will be unable to use the frequency.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Dave Andreae
Thanks!
http://www.parallax.com/detail.asp?product_id=27985
Another very popular option is the XBee's from maxstream.net and available from digikey. They employ error correction and clear channel assesment and retires meaning if someone else is 'talking' they wait their turn. It's very easy to get multi device comms going, with each having unique addresses. One problem is they are 3.3V devices. For a time I sold 5V to 3.3V adapter boards. I still have some blank PCB's if you would like a couple along with a digikey parts list, please private me your address and I can mail them in regular mail. The link also has some sample code in the documents at the bottom of the page.
http://www.selmaware.com/appbee
-Martin
StampPlot - GUI and Plotting Software
Southern Illinois University Carbondale, Electronic Systems Technologies
