How to monitor and ground a 5v-12v p-p signal?
How do I condition a signal that varies from 5v p-p to 12v p-p with a 3.3volt input. I also need to ground this signal for 1ms over a given frequency. I am currently doing this with a BS2, but I wouldnt trust the input to hold up to that for a long time and wouldnt trust the propellers 3.3v input at all at 12vp-p. What kind of circuitry do I need to pull this off?
Jason
Jason
PS. Your signals are actually 8V to 24V p-p.
Alternatively you could just use a simple NPN with the current limit resistor in the base to handle the signal and feed the collector to the prop with a pull-up resistor.
There is no need to preserve the actual voltage level as all you want is the timing.
Why do you want to ground the sensor only when the RPM goes too high?
*Peter*
Peter, I like the NPN idea.
Edit: read 'lowest expected input frequency'
Post Edited (Skogsgurra) : 9/15/2007 9:20:39 PM GMT
Good point. I believe the answer would be 6V, since there's no current, hence no voltage drop through the base resistor. A simple protection device would be a separate diode between base and ground to limit the reverse voltage to 0.6V. The same technique is used to protect optoisolator LEDs that are subjected to AC voltages.
