LCD Displays — Parallax Forums
LCD Displays
JessicatJessicat Posts: 3
edited 2008-01-23 10:06 in BASIC Stamp
Which LCD display is the best documented and easiest to use with a BS2?
  • quispqixquispqix Posts: 64
    edited 2007-09-12 04:32
    Most all are very well documented. If that dose not help this forum will.
    And alot of Parallax products are used in other electronics forums (robotics avr and sensor forums)
    www.parallax.com/detail.asp?product_id=27977
    This is a three pin very good start +5volts Vdd, Vss, and Tx. I like it!
    I can never find anything to eat at break-time!
    skype me: quispqix
    echolink: 184783 KC0LGV
  • JessicatJessicat Posts: 3
    edited 2007-09-12 04:34
    It says "this circuit is not supported by parallax".............. what does this mean? What do I have to get to make it work with a BS2?
    edited 2007-09-12 04:40
    This device can be connected to a PC serial port using a MAX232 line driver.
    The circuit isn't supported by Parallax, but it's possible to make this connection with a few dollars of parts.
    This circuit ' a MAX232 line driver' is not supported by (check with Parallax I don't want to mislead you about their products.
    but you can search about a MAX232 line driver
    http://forums.parallax.com/showthread.php?p=640507
    The LCD module is not connected directly to the serial port of the computer, The BS2 is connected on your Board Of Education BOE then this is to your BS2 Stamp and then Pin 0-15 is connected to the LCD module
    So on the code SEROUT 0, 84 [noparse][[/noparse]"Hello Jessicat"] The LCD modules Tx pin is connected to your BOE pin 0 (zero)
    And +5 is @ Vdd and GND is @ Vss Tx is @ P0
    I do work for food!
    skype me: quispqix
    KC0LGV
    Echolink: 184783
    users.adelphia.net/~quispqix
    Post Edited (quispqix) : 9/20/2007 12:46:49 AM GMT
  • bograbogra Posts: 27
    hi,is your Basic Stamp2 and LCD working now properly?
