SHIFTIN Example at 50 Mhz — Parallax Forums
VonSzarvasVonSzarvas Posts: 3,634
edited 2007-09-11 11:11 in General Discussion
Hello all,
In the SX/B help chm, is an example "SHIFTIN Example using ADC0831"
The device setting are:
DEVICE         SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ          4_000_000
If I change them to:
DEVICE          SX28, OSCHS2, TURBO, STACKX, OPTIONX
FREQ              50_000_000
it stops working. I get samples of FF from the ADC.
Is there some guideline somewhere which I am clearly blind to find about how to modify the SHIFTIN for different frequencies?
Thank you.
  • JonnyMacJonnyMac Posts: 9,800
    edited 2007-09-11 09:16
    The example has the clock speed multiplier enabled -- try removing this or changing the setting. SHIFTIN and SHIFTOUT should be FREQ setting agnostic, but there may be something with the speed multiplier that is being adversely affected at fast clock settings.
  • VonSzarvasVonSzarvas Posts: 3,634
    Yes, that was it. The clock speed multiplier - commented out and issue solved.
    Cheers.
    SHIFTIN Dio, Clk, MSBPOST, tmpB1\1  ', 4       ' start conversion
    SHIFTIN Dio, Clk, MSBPOST, tmpB1     ', 4     ' shift in the data
