A data logger for drag racing
Hi Guys
I put together a 2 axis logging accelerometer over the weekend. It displays the data on a LCD and logs 3500 records, approximately 10 per second. One can then download these to a PC and graph them in Excel. It was one of those fun projects where everything worked 1st time and I could just copy and paste the code from Parallax’s various examples (accelerometer, LCD, flat EEprom, Comms – Thanks Jon and others!!!).
There are a lot of car fanatics round here. For some time now, I’ve been thinking about a logger as my next project. It would record acceleration, road speed, RPM and time. Later, I’d like to add information on the position of the gas pedal (accelerometer on a strong magnet to clip onto the airflow quadrent). The device must be portable so that each racing maniac can clip it onto his hot automobile and drag up and down the road for 30 minutes. He then downloads the information and we analyse it. The device is put on the next vehicle and we do it again.
The device would replace the old, expensive and very inaccurate dynamometers that are only available in Durban which is over 50 miles away. I believe the information would be more accurate and much more useable. It looks like you’ll be able to see flat spots and bad ratios much easier by just looking at the rate of acceleration at any choice of speed/gear/gradient/Pedal position. (Memsic have a paper on how to calculate both acceleration and gradient at the same time – the math is a bit beyond me but I’ll go to the nearest university)
My question – How do I read road speed? GPS is too inaccurate round here. I can use a 5th wheel and I have suitable (industrial) encoder but fitting it to the car each time is a hassle. Is there some other inexpensive option?
Kind regards from Kwa Dukuza (Where ever that is?)![tongue.gif](http://forums.parallax.com/images/smilies/tongue.gif)
John Bond
John Bond
Jeff T.
Most of the cars in South Africa are front wheel drive round here (Japanese, Korean, or small German and French). Quite a number still have cable drive speedo's. All the racing vehicles have non standard tyre and wheel sizes. This is why I preferred a 5th wheel to measuring driveshafts or Speedo impulses.
Also, spinning the wheels is actually counter productive. That is why the really high performance cars have traction control. I would also like to measure this spinning (by comparing RPM to actual road speed - I'm told that under 10% slip between tyre and tarmac gives the best traction).
The speed cops round here use radar and infra red. Can I somehow do this in reverse but bounce some signal off the tarmac (pavement or whatever you call it)?
I'm very keen to try and avoid an impractical 5th wheel.
Kind regards
John Bond
My friend does a lot of racing and his system is a permanent fixture to his dragster. But you might be interested in the sensors available which are sold separately and if I remember are not too expensive. I'll post the link when I find out which system he has
Even if you want to manufacture your own sensors it might give you some ideas.
Jeff T.
We're a 3rd world country so as an engineer (and quite a senior one too), I don't earn a lot. I will probably copy a sensor rather than buy.
I got the spark plug sensor for measuring RPM to work on my development board last night. I'm going to have to do some thinking because I'd hoped to sample all data every 50ms on but a spark only occures every 200ms on a 4 cylinder engine at an idle speed of 600 RPM. Possibly measure every 50ms, average and record every 100ms, interpolate if there's no new data.
How to measure road speed is still bugging me...
Kind regards
John Bond
www.racelogic.co.uk/?show=VBOX-Products-CAN_Speed_Interface
It looks as though you Yanks need to use·CabBus in your "Battle Ships"
John Bond
I have a 1953 Ford 4 cyl tractor and·I would like to build a tacometer for it. I am interested in the circuit and code you are using with your spark plug sensor. Do you mind sharing?
MikeS
Sorry about the delay in responding
I used the attached circuit. Stuff out my scrap bin. I'll probably use an optoisolator between this and the microcontroller on the final circuit.
I intend timing from positive edge of the (spark) pulse to the next positive edge. I did the trials on a BS2 only to checked for signal. I'm using an SX on the final device. Unfortunately the spark doesn't occure frequently enough for me to count the spark pulses.
Hey there are a few of those old Fords round, the Brittish made ones though. Also quite a number of the old Masseys from the mid 50's, some still doing work. You can still buy some Massey Fergeson spares. I saw a head gasket set, valves and petrol pump being sold to an old black farmer about a year ago. The farm I live on has a number of Catapillar D40 (+-1937). They are dead but there are enough of them to build a couple of running crawlers. Plenty of the Brittish (stationary) Ruston Oil Engines from the 1920's - There must have been a good Ruston salesman up here about then. They were used to drive water pumps gensets and mills.
Kind regards from Kwa Dukuza in South Africa. I hope you enjoy your Trekker...
John Bond
