Very high power dissipation: Prop fried?
Dear All,
I have a propeller on a Proto board, that all of a sudden exhibits an amazing power dissipation. The chip got so hot that I actually burnt my finger when I wanted to feel its temperature.
I have tried to isolate the problem, and have disconnected all pins to external peripherals, but the dissipation stays. The chip takes >300mA, with only the external crystal connected.
Still, I am able to program the chip, and it runs like normal.
Could I have damaged one or more output stages in the chip in a way, that explains this behavior? Obviously I would like to prevent something similar from happening again, so I would like to understand what's going on. Any ideas?
Best regards
Oscar
Best regards
Oscar
The only time I had the prop get warm (not seriously hot) was running the multi cog routine - which was intended to demonstarte this .. is the draw still high·with a·simple prog ?
Can you run a prog. which uses the xtal multiplier e.g. VGA .. Just to check if the PLL is damaged..
300mA is not too encouraging though !
John Twomey
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 9/10/2007 11:13:17 AM GMT
Regards
Oscar
John
Would your theory be able to explain the dissipation though?
I'd say something would have to be damaged to get it this high?
Keep us updated - when you get a chance to check it out further..
John
Can you device a test that would give meaningful results to you?
Regards, Oscar
do you use a Parallax Proto Board?
@John
I had the same problem with one of my Parallax protoboards.
The PLL is gone and i only had attached a VGA Monitor. I still can programm it
but the other I/Os are dead.
When i look at the schematic diagram, there are 3 x 10uf caps, but this caps are not at the board.
I can locate 3 x 100nf caps but no 10uf cap. The Regulators are running without 10uf caps :-(
best regards
Franz
Please visit my online Propeller at:
http://achatz.xs4all.nl
Are the 1206(ish) sized ceramic caps not 10uF? They are located by the legs of the regulators, a single 1uF cap is located close to the prop itself.
Graham
Yes I use the proto board from Parallax.
Regards
Oscar
they look like 100nf ceramic caps.
But ok, when these are the 10uf caps then the 100nf caps are missing :-(
Franz
You said you had no VGA connections or fancy things ! to check PLL - I noticed though that you mentioned MAX3232 - why not run a full duplex serial test program to hyperterminal or similar ...
John
I have done no extended tests up to now, because I was afraid to kill the prop completely by heating it up too much.
Thanks and I will keep you posted,
Oscar
Lunch cures all problems! have you had lunch?
Nevertheless they are a marvelous piece of engineering in the line of the other "stamps".
I severly disabled it some weeks ago, by experimenting to boldly with video. It now sucks >200mA and the tiny 5 and 3v3 regulators on the hybrid board get hot (obviously!) in addition to the Prop itself.
Funnily programs still run, except the pins I used for video don't work any longer. I didn't check more but I can the next days...
Paul Baker
So it seems these are the culprit. What could have caused such damage?
Thanks for your support
Oscar
Any further ideas?
Paul Baker
Best regards
Oscar
Paul Baker
