I2C BS2px Max6953 5x7 LED Display Driver
I am trying to figure out how to send the character data to this driver. I am using 4 single color 5x7 displays.
I have only one slave at $A0 for now. When I send $07 (display test) for the Command Address and a 00000001 for the Data Byte, I get all LEDs in the matrix lit.
Using:
So now I reset, change the Command Address to $60 (write digit 0, p0, p1, w/ same data) and Data Byte $41 (capital "A") and nothing happens.
Using:
I am trying to figure out the basic way to send the characters to each digit.
I requested 4 samples and got them, and will eventually add them for a total of 16 characters.
MAX6953 Data Sheet:
datasheets.maxim-ic.com/en/ds/MAX6953.pdf
Using:
I2COUT SDA, $A0, $07, [noparse][[/noparse]$01]
Using:
I2COUT SDA, $A0, $60, [noparse][[/noparse]$41]
MAX6953 Data Sheet:
To be honest, I didn’t scan through the datasheet, however I wanted to suggest a possibility you can look into. On the MAX7219 when you turn on display test it remains in that mode until turned off. You never say you’re turning off the display test mode so it may just be in that mode. I hope this helps. Take care.
For example, I am trying to send letter "A" to digit 0.
$A0 is the slave address, $60 is command address for Write Digit 0 (P0, P1 Same Data), $41 is the Data Byte for letter "A".
Most of the I2C posts on this site and the web are for EEPROM and I/O Expanders, not any LED drivers like this.
I have read the datasheet and it seems simple enough that I understand it but I think I may not since it isn't working beyond the test mode.
