HB-25 speed up or down
I have been looking for some examples of controlling the speed of the HB-25 speed control that I just got.What I would like to do is control the speed with· two push buttons one to increase rpm and the other to decrease, I·will be using this on my waste oil·heater to control oil pump speed. Also would like to monitor·the rpm with magnetic sensor so that I can display Data·with a serial BPI-216 LCD module, Show the·actual rpm and make it adapt. As the heater runs almost 600 hours a winter and burns almost 750 gallons of waste oil the filter tends to get·restricted after 200 to 300 hours,·so if I new how much offset was being used to maintain a steady rpm I would know when the filter was restricting the inlet flow of the pump.·Also thought about a vacuum sensor?·I have some·Derivative Algorithm code that someone wrote,·it is very interesting how this code works, nice·work! ·It would be nice to incorporate this feature in my oil flow control. Well thanks to all you·out there banging out code, its nice to have such a great Forum. Thanks·also to Parallax, ·David
Post Edited (dbj) : 9/10/2007 5:02:54 AM GMT
You should breadboard it and give it a whirl!
Post Edited (dbj) : 9/14/2007 3:00:09 AM GMT
Have you seen this thread?
http://forums.parallax.com/showthread.php?p=629063
This describes a ratio metric approach to reading a POT through RCTIME that might be easier to incorporate into setting the pulse width for an HB-25
An added benefit of ratio metric reading is that any temperature drift that may affect the returned value is minimized or mathematically canceled out.
The example in the thread provides a 0 to 100 value that indicates a percent for the output. This could easily be changed to whatever is appropriate for your application.
Beau Schwabe
IC Layout Engineer
·would like to change the bar graph to go from right to left insted of·left to right ?
Post Edited (dbj) : 9/15/2007 8:24:44 AM GMT
