My Propeller is dead ?
I hope not...
All of a sudden, although it was running like a charm, my Propeller froze (everything stopped in the middle of the action), and since then I can't bring it back to life. IDE doesn't see it any more. I've double-checked all connections, Vcc pins, and all seems ok.
Has anybody here an idea of what could go wrong, and hopefully how could I put it back in order ?
Many thanks in advance, because I started to play with it one week ago only, and I'd like my experiment to be a bit longer than that
Best regards
Eric
More about my robotics related activities on : www.pobot.org
Best regards
Eric
My computer, http://forums.parallax.com/showthread.php?p=630466
Eric
Post Edited (RicE) : 9/9/2007 10:30:13 PM GMT
Is it a homebrew setup ?
'Necessity is the mother of invention'
Around 32mA. I didn't measure power consumption before, but it seems not abnormal. Is it ?
If I remove both chips (Propeller and EEPROM), current is around 24mA (power LED draws 10mA for itself). So the Propeller chip seems to eat only 8mA. Seems normal, according to datasheet, since it does not seem to running any code.
No inductive load. Just a couple of LEDs.
In fact, it is the PE kit. I've setup the lab as described in the doc, and am working with it in this form since last week-end (see picture). The only external devices are the I2C LCD and the I2C compass (on the rightmost breadboard)
Eric
Post Edited (RicE) : 9/9/2007 10:46:28 PM GMT
It is possible that the underside of the breadboard has some moisture around the crystal circuit which being even slightly conductive will surely upset this circuit.
*Peter*
Unfortunately not. As I said in my first message, the IDE does not see the chip any more.
I tried to remove it and then to move it to other connections of the same rows, but without any success.
I also tried to boot the Propeller without the USB interface plugged in, to check if there was no problem in this area, but without any effect neither.
Eric
Post Edited (RicE) : 9/9/2007 10:53:17 PM GMT
The prop runs down to 2.7V but a loading the battery during boot may cause the voltage to drop even momentarily and reset the prop again and again. Batteries aren't suitable for heavy loads like the LCD backlight which can draw over 200ma.
*Peter*
Impossible : it runs from a lab PSU, which is BTW backuped by an UPS
Yes. I've removed all but the Popeller and the EEPROM (plus the regulators of course). The IDE does not see it when using F7. So trying to program the beast is not possible.
I've discussed with one of my co-worker this morning, and he suggested me to check if the RESET pin wouldn't be tied to GND by some strange effect, thus holding the Prop in reset state. I'll look at this tonight at home.
However, thanks everybody for taking the time to send me suggestions. I hope being able to bring the chip back to life ASAP.
It's important for me, cause it's not mine, since the kit has been lent to me by a friend from the robotics association (he just received it but has no time for the moment to investigate it, and since he knows that I'm a big fan of such toys....). I know that I'll always have the option to order a new chip from Parallax, but... And in addition, my trust in it would be a bit altered if I end up without knowing what happened.
Eric
Just one little thing I thought of - Have you shut down your P.C and restarted it ... I noticed that when my P.C was on for a few days for some unknown reason I was unable to program a prop - When I restarted the P.C all was well .. I seem to remember someone else having a similar issue..can't locate the thread at the moment though..
Are you using the latest IDE ?
Does the FTDI USB to Serial·Device show up under device manager ? (USB Serial Port)
You say: your 'trust would be altered' ... This is unusual for a prop - I have found them to be pretty bomb proof .. Hopefully it is only a minor issue - do keep us informed..
Rgds,
John
Post Edited (QuattroRS4) : 9/10/2007 4:14:29 PM GMT
Try a laptop (running off battery). You might have a ground loop.
Scott
I'm not sure to see the point here, since when the Prop is unplugged from any machine it doesn't work much more.
Yes. I'm just back home, and and switched the PC back on. I first try the Prop alone, checking for the /RESET suggestion of my co-worker. No luck : it's high (as long as the reset button is not presed).
Yes. I started to play with the Prop one week ago, and downloaded everything from the web site.
Yes. There is no problem with the link itself, since I can see the LEDs on the plug flashing when the IDE scans the COM ports trying to find the Prop.
However, if ever the link was down, this would not prevent the Prop from running alone since the last program has been downloaded in EEPROM too.
It's the very first time I encounter such a problem with µC. And I've play with lots of Atmels, be it for fun or for work. I have to say that when doing my very first tests with the Prop, it happened once that the beast was frozen. But I thought at that moment that it should be my program that hung it. After a reset (or a power down, don't remember), all was back in order. Maybe it was some premise of a latent trouble....
Eric
Post Edited (RicE) : 9/10/2007 10:54:49 PM GMT
You didn't swap Rx / Tx at any stage by any chance?
John Twomey
Hi John,
Nope of course. In fact the thing was working perfectly from the beginning, and the heart of the system (ie the Prop, the EEPROM and auxiliary components) have been setup as indicated in the PE Kit notice, and left untouched since then. The only changes I made during my experiments was adding LEDs, then the LCD et al.
In addition, and as I've mentioned in one of my first messages, the setup as shown in the picture, with the LCD and the compass, has worked correctly for a while, and then stopped suddenly without doing anything special, but looking at it from time to time. I was not aware having the same super-power as Cyclop in X-Men
Best regards
Eric
I feel for you ... I don't mean to be going over the simple/standard problems but I suppose its 'basics first'... I am sure you can understand that.. Was care taken·connecting any 5v device to the prop i.e. at least a 1K resistor between any 5v input to prop ?
John
I fully understand your method and agree with it : try the most obvious things first, because they are often the ones that are overlooked.
But yes, I've taken appropriate care, using the combination described in the sticky thread about this topic, ie 10k serial resistors between 5V level I2C signals and 3V3 ones. I've not put 3v3 Zener as additional protection, because I had none at hand, and BTW it was written to be unnecessary.
I'm not sure to understand which wire you are referring to. In the area of pin 15, the only red wire I can see is the connection of pin 12 (Vdd) to the 3V3 positive rail. Was it this one ?
Eric
Brian
uController.com - home of SpinStudio
I can send you some parts so you can swap a few things out. It'll help us find out what failed more quickly. Please use the email link to the left of this post to contact me.
In the meantime, one other suggestion: disconnect all peripherals (the LCD, LEDs, etc) from power and the Propeller Chip. Then, verify that it's still not accepting downloads. (Sorry if this was already done and I missed it in the discussion).
Andy
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 9/13/2007 5:15:28 PM GMT
Sorry Fred, I don't know why, but I've read that you mentioned a "red" wire, although you only mentioned a "wire". As Brian said, it is the common anode of the LED bar on the leftmost of the picture.
Already done, but I've repeated the test to check again. I unplugged all, but the EEPROM and the Propeller, and IDE is still not able to detect the Propeller.
I suppose you meant "Eric"
This is very kind from you. I'll contact you at once.
Again, many thanks to all you for supporting me.
Eric
"No I'm fred"
If I don't fry all the chips, I can send you what will survive
Eric
I'm now in the process of re-creating the complete application I was working on at the moment the problem happened. For now, it works fine with all but the I2C compass (CPMS03). Not that it does not work with it, but that I've had no time yet to test. As promised to Andy, I will keep informed of the results.
But anyway, hats off for the way Andy managed my problem. I've not encountered many companies offering such a quality support and such a generosity.
Thanks again.
Eric
