Simple question about Beau-Plexing LEDs
Guys,
¿Qué es esto?
Was ist dies?
Что является этим?
The story is this...and as always the story is completely true:
I tentatively decided to make a Propeller based birthday present for daughter dearest. I don't think she would appreciate a barely functional, servo-based coil winder, and I have hundreds of LEDs laying around from a project that got abandoned by my (now defunct) tech team.
So, I've decided to Beau-Plex something together... I'm thinking of an LED wall clock that spells out... "Take Your Pill" every 24 hours, in a variety of hypnotic patterns.
Anyway, with almost half a clue as to what I am actually doing... I believe that I have implemented a one LED "Beau-Plexed" test circuit. To my delight, I found that if two Prop pins are connected to the anode of an LED and set to output... and one of those pins is set to high and the other is set to low... and the cathode of the LED is connected to ground... very little happens.
... just like Beau promised[noparse]:)[/noparse] Amazing.
I then went to the app note posted by Graham and the explanation centered around a reverse bias across the LED, and I'm not buying it.
I don't see how my arrangement can reverse bias anything...(and therefore, I suspect that I am misunderstanding the discussion).
I put an amp meter across the legs of my Beau-Plexed LED... and the current dropped by 3.6 millivolts between the LED ON (53.2 milliamps) and the LED OFF (49.6 milliamps) corresponding to 2.3 volts and 1.8 volts.
I've concluded that either Beau-Plexing and CharliePlexing are not the same or that CharliePlexing has nothing to do with reverse bias across the LED.
Which if either of these alternatives is correct?
How would I apply and control a reverse bias across my LED?
Rich
p.s. I don't want to pressure you guys, but my daughter's happiness is in your hands[noparse]:)[/noparse]
By the way... about my current project... "the worlds slowest coil winder." Things are progressing nicely. I figured out the spindle design and I got the Bank to sign off on a purchase order for 50 meters of wire. I'll be posting methodology and results soon.
¿Qué es esto?
Was ist dies?
Что является этим?
Rich
I would bet dollars to donuts that in the mode that produces the 1.8 volts the wire heats up... which would mean that resistance could be cast as a function of information statistics applied to the current.
Rich
This is where you misunderstood things: "if two Prop pins are connected to the anode of an LED and set to output... and one of those pins is set to high and the other is set to low... and the cathode of the LED is connected to ground"
If you connect two output pins and set one high and one low, you are probably very close to overloading the device because one pin is feeding directly into the other, which is sinking current with very little resistance. Do it like this instead:
Connect LED cathode to one pin and LED anode to the other pin.
Output high to the anode and low to the cathode. LED lights.
Output high to both, or low to both. LED is dark.
Output low to anode and high to cathode. LED is dark, because it is reverse biased (wrong polarity).
Connect another LED (with cathode to first LED's anode) - and it should com on.
So, you are changing polarity from the LED's point of view. Even if you are not outputting anything but 0 V and + 3.3 V.
BTW, it is not recommended to run outputs short-circuited. Put at least a 47 or 100 ohms tresistor in series with the LED.
(1) Understand how a matrix works? 1 of N going "plus" and 1 of N going "minus" ? So you kann address NxN LEDs
(2) Now connect JUST THE SAME N lines as row AND as column drivers. Don't ask - Do it!
(3) Of course you now can no longer use the diagonals as they are connected to one line only..leaves NxN - N possibilities
(4) Light them as you would have done in case(1)
I upload a 2 and 3 silvaplex diagramm...
Post Edited (deSilva) : 9/9/2007 8:44:32 PM GMT
Beau Schwabe
IC Layout Engineer
Later today if I get a chance, I'll show a schematic of what that would look like.
Beau Schwabe
IC Layout Engineer
Graham
The formula is
Total LEDs = N*(N-1)
where N is the number of IO's used.
deSilva,
I can see how your method works well with a 2d-matrix, but I'm not sure how it would lend itself to a 3d-matrix.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 9/9/2007 8:09:29 PM GMT
here is a post with nice sample (see post 9 from OakGraphics) i think it's the 'Beau-Plexing' with clear schematic.
http://forums.parallax.com/showthread.php?p=667572
Here is my proper schematic witch show that the principe is to connect a couple of led 'flipped' between two pin. And repeat for each possible combinations with each others pins.
dro.
in medio virtus
Post Edited (inservi) : 9/9/2007 8:30:17 PM GMT
All schematics given (Beau's, Inservi's, mine) are TOPOLOGICALLY identical.
I was only interested in the question how it works, and gave the answer that seems most obvious to me.
Another question is, how to ARRANGE this GEOMETRICALLY. Beau's schematic will help to form a 10 story tower with 9 LEDs each.
I think the question how to CONSTRUCT it MECHANICALLY is the moste tricky one...
Regards, Dave
