Bus Connectivity between devices?
chubs1646
hello all,
I dont currently own a propeller setup, but while looking and admiring the overall concept I was curious as to if anyone has figured out if it is possible to connect several propeller chipsets together over the bus system, and if it is possible if anyone has experimented with being able to control other chips with the cog of a different chip? this may have already been addressed but I didnt see anything posted for it. thanks in advance.
I'm also working on something like this myself: http://forums.parallax.com/forums/default.aspx?f=25&m=214802
I read and read and read and finally ordered a Prop. Reading about it doesn't do it justice. There is so much available in the design that it will boggle your mind.
Jump in... if you aren't completely amazed and satisfied, I'll buy your Prop...
The half life of the effort you spend will be at least 10 years and probably much longer... that's a particular advantage.
Wasting time and effort simply isn't possible with the Prop.
Everything you do will realize a persistent value.
Rich
Bias without prejudice is rare.
