LC7932....A 16 bit Bidirectional Shift Register...Here is a Place where you can — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2007-10-11 00:21 in General Discussion
Hi EveryOne
I just Bought two these 16 X 32 Dot Matix Led Display that has these LC7932 IC Chips in them
16X32 DOT MATRIX led display from “http://www.futurlec.com/Specials.shtml
I just want to know·if i can use them or am i going to have remove the displays and make my own board for them
Here is a link to the Data Sheet http://www.datasheetcatalog.com/datasheets_pdf/L/C/7/9/LC7932.shtml
I know about these post
http://forums.parallax.com/showthread.php?p=651690
http://forums.parallax.com/showthread.php?p=667572
What i want to know·is if someone has got this to work the way they wanted to work
··Thanks for any·idea.gif·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 9/26/2007 4:19:07 PM GMT
  • pwillardpwillard Posts: 321
    edited 2007-09-08 15:51
    The LC7932 has a few more options than the 74HC595, but it is basically the same and should be pretty simple to fill in the gaps (Like setting shift direction, setting BEO HIGh, etc).
    There's nothing like a new idea and a warm soldering iron.
    edited 2007-09-17 18:38
    Sam,
    Where are they sold? If there is a good price on them someplace where I am likely to order parts I may grab a few and write some example code. Take care.
    edited 2007-09-17 21:39
    Chris
    I did a search at Digikey and Mouser and no such luck in find these chips I will PM about this matter
    Sam
  • NewzedNewzed Posts: 2,503
    edited 2007-09-18 13:46
    Sam, have you found the LCDs yet?
    Sid
    Yesterday is history, tomorrow is a mystery, and today is a gift.
    That is why they call it the present.
    Don't have VGA?
    Newzed@aol.com
    edited 2007-09-19 00:36
    Sid
    What we are looking for is a 16-Bit LED Driver chip number LC7932
    The only places that has them you have a min $ 100.00 or more·to buy and i don not
    want that many of them
    If some one knows of a place where you can buy·10 of· them so i can give five of them·to Chris to play with them that would work just fine
    Thanks to any one that can help ahead time
    Sam
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2007-09-19 00:59
    Sam,
    I have given up on this one.··Unfortunately the LC7932's are tied together and I have explored this to about the extent I can take it. I spent alot of time on this and asked other engineers there thoughts about this.
    As you stated earlier....
    Here is the BS2 link (last post at the bottom):
    Here is the SX28 link:
    http://forums.parallax.com/showthread.php?p=658966
    However,
    I have found that the best method for me is to use P-FET's on the Anodes and A6821's on the Cathodes. Unfortunately P-FETS (2-10 Amps) are in surface mount form only so a special board will have to be made for them.
    You can get free samples of the P channel FETs from Fairchild Semiconductor and the A6821's from Allegro Microsystems (free samples). You will put the current limiting resistors on the outputs of the A6821's. I am currently working on an LED display which is comprised of (5) 8x8 Bi-Colored LED Matrix modules (actually you can get 3 colors). The 8x8 BiColored LED Matrix modules are sold on Ebay for under $20 (including tax) for 10 of them. I will be posting my design in a couple more weeks when I get finished wiring it all together and write some code. I hope to have this working all from an SX-28. That's amazing. However, If I want to control individual 8x8 modules I will probably need to move up to an SX-48 because I will need more output lines to control the /OE lines of each A6821 to control what color the module is displaying (green, red or yellow). More to come...
    Post Edited (T&E Engineer) : 9/19/2007 1:13:31 AM GMT
    edited 2007-09-19 16:43
    ·Chris··
    I think i have found a placse to to buy 12 of them i am just waiting to find out
    how to send the payment to them
    I will let you if i can get them
    I found out that these LC7932 chips they are longer being made
    This is on Sanyo web page
    T&E Engineer
    Thank you for your reply
    I will watching what you come with ..................idea.gif....................smile.gif
    Sam
    edited 2007-09-19 17:11
    I may be interested in purchasing some of these LC7932 LED driver chips - especially if they are in DIP form and not so much SMT. Let us know if you can still aquire them.
    In the mean time, if you have purchased the 16x32 display from Futurelec and have not tried out either the BS2 or SX-28 version - I invite you to do so.
    These displays·really have a nice brightness to them. I have been searching everywhere for LED displays and can not find any. So for >$20 it's a great deal!
    However, I can't remember the current drawn, but I beleive I used a higher current 5vdc power supply for the display LEDs as well as the standard 5vdc from my Parallax Professional Development Board (PDB) for the display·ICs and SX-28.
    Good luck. Attached are the latest program versions.
    edited 2007-09-19 17:38
    T&E Engineer
    I will see if they can get more than 12 this all they show on hand
    but i· will let you know now if you want to buy $100.00 or more i can
    give a few web links to those if you want me to
    Please let me know if you want to give them to you
    Sam
    edited 2007-09-19 17:42
    No, I will not spend $100 on components for hobby projects.
    However, if you can get more from your supplier in reasonable low quanties like 3-10 or so·let me know.
    I did look for them some time back and was unable to find them either.
    Thanks for the good work on this.
    edited 2007-09-19 18:05
    T&E Engineer
    I know what you mean
    I·do not like to send that much money·any one Project
    I will see what i can do
    Sam
    edited 2007-09-26 16:19
    T&E Engineer
    Here is where you can buy the LC7932 chips
    http://www.bdent.com/search/part.jsp?partnum=LC7932
    Sam
    edited 2007-09-26 17:36
    Sam,
    I just ordered 3 of the 30 pin DIP (LC7932) versions. They were $7.32 each + $6.25 UPS ground shipping. I did not like how they did not tell you how much shipping was going to be till the end - so I chose GROUND shipping.
    Thanks for the great find!
    I will let you know what I can design with these.
    edited 2007-09-26 19:34
    T&E Engineer
    I just order 3 of them my self but·I took the $6.25 UPS ground shipping
    They are out of stock for now·they will email me if they can get more of them
    so if they can i will post it
    Sam
    edited 2007-09-26 19:38
    Hmm.
    The screen says they are in stock. I did not get an email or screen warning stating mine were not in stock or delayed.
    I'll let you all know. So far it should be scheduled to go out I'm assumming today or tomorrow (most likely).
    edited 2007-09-26 20:18
    T&E Engineer
    I call the company when i placed my·order·the sales person told me that some one had order 3 of them today
    ··I placed my order they are now out of stock i though that you may have been the one that had order some
    Here is another link where you can find some the only problem they have a
    Min of 25 of the same item $ 5.37 each which is about $130.00
    http://www.tenfourltd.com/PartSearch.php
    Sam
    Post Edited (sam_sam_sam) : 9/26/2007 8:32:15 PM GMT
    edited 2007-09-26 21:40
    I appologize but had no way of knowing that they only had 3 in stock and it sounded like a good number to have.
    Let me know when they get more. I hope you can get some. However, I am not going to buy 25.
    Sorry. This is weird and a bit ironic.
    But I do greatly appreciate the lead.
    PS: I just checked my email and I got a UPS notification that the chips were shipped and can expect them Friday (2 days) - not bad for ground shipping. But PA is not too far from KY.
    Post Edited (T&E Engineer) : 9/26/2007 9:45:01 PM GMT
    edited 2007-09-27 17:28
    T&E Engineer
    You do not need to appologize
    When i fond them i was on break at work and only had time to post the link so i am glad that you where able to order some
    I was going to order 6 all together but that alright if they can get them i may even find more of them some where else if not
    This is weird and a bit ironic. Yes it is I have look at alot of comany web sites
    and never seen where you had to order 25 of the same item and yet have a break down 0 to 5 for a price 6 to 10 for a price and so on and tell you that
    you have buy 25 of the same item and tell· you that there min is $50.00
    Sam
    Post Edited (sam_sam_sam) : 9/27/2007 5:38:02 PM GMT
    edited 2007-09-29 00:15
    SAM,
    I got my (3) LC7932 LED drivers today. BUT there is a problem. I ordered the DIP style versus the surface mount type. I assumed it was like most all DIPs that I have used being 0.1" between pins. However THEY ARE NOT. They do not fit into a solderless breadboard like I expected. They are 1.79 mm appart not 0.1" appart between the pins. 30 pins·fairly·close together. I still may be able to rig up a board to mount them on a solderless breadboard but certainly they wont fit into a standard 0.1" socket either. This sucks for me and maybe you too.
    edited 2007-09-29 14:47
    T&E Engineer
    If you are going to make a board to use these chips and the led displays
    Please let me know and i will go half the cost to have a board made to use them
    Yes this sucks they do not make thing easy do they
    Sam
    edited 2007-09-29 17:20
    What I was able to find out was not much. The LC7932 uses a DIP30S package. But I'm still not sure if it is 3061-DIP30S or DIP30S. There is nothing on the internet about the DIP30S except 1 Sanyo datasheet all in Japanese and somewhat short so probably not much information. I also saw reference to a 29T27 adapter which may or may not be correct. No information at all found about this.
    Due to the lack of availability. Yes I checked most of my part sources - nothing on this DIP30S socket.... I think what I will do is simply and carefully solder short wires (22 gauge? or smaller) to each pin and use it that way on a solderless breadboard. It seems to be the easiest and at this point (only) way to use this chip.
    Does anyone know about this DIP30S package by Sanyo and where a socket or an adapter can be purchased?
    I will let you know of my progress and probably take some pics if you want to see it when done later tonight or tomorrow.
    What a pain this has been.
    edited 2007-09-29 21:33
    Here is what I did to make an adapter:
    Parts: Small perf board (Radio Shack), 2 sets of 15 male 0.1" headers (parts store - Jameco, Mouser, etc.), 30 gauge insulated wraping wire (Radio Shack 278-501,2 or 3), 15w soldering iron and a new 15w tip (Radio Shack), small rosin core solder (Radio Shack 64-013 or something), 22 gauge solid (Radio Shack - comes in a 3 pack or whatever), very small needle nose pliers and cutters.
    1. Cut the bottom 30 thin leads off of the LC7932 (leave only the upper·wider part).
    2. Get 2 sets of male 0.1" headers of 15 each and push a short piece of 22 gauge wire into each one and solder. Cut to about a 1/2" afterwards.
    3. Insert the 2 male headers into the perf board and make enough room for the LC7932 to fit.
    4. Carefully start pre-tining each wide lead on the LC7932 and cut 30 1-2" 30 gauge wires and solder closely to each wide lead.
    5. Trim back each of the 30 wires coming off of the LC7932 to about 1/2" total length.
    6. Bend back the 22 guage wire posts out from the perfboard top back to the outside.
    7. Use the needle nose pliers and strip off a 1/32" off of each end and carefull solder the wires to each of the posts.
    8. Check every wire and connection to make sure non are touching eachother and push down carefully the LC7932 to rest on top of the perf board.
    Here are some pics I took of the adapter. As you can see the last pic shows the original bottom side of the AD-501-B 16x32 LED display. It shows the comparison of the surface mounted LC7932M to the DIP30S LC7932 in the custom adapter I made.
    I burned a couple of fingers on my soldering iron grabbing it and putting it back down so many times - so have plenty of ice water too! lol.
    Time for a break. Total project time ~2 hours.
    648 x 486 - 57K
    648 x 486 - 44K
    648 x 486 - 55K
    648 x 486 - 55K
    648 x 486 - 89K
    edited 2007-09-30 03:34
    www.sourceresearch.com/Store1/quickstore.cfm?ProductID=54461&do=detail
    - Stephen
    edited 2007-10-01 01:19
    T&E Engineer
    Thanks for sharing what·you did here
    Thanks for sharing the photos of what and how you did it
    I know what you mean i have done this a few times my self·
    Keep up the good work and keep us post on it come along
    Sam
    edited 2007-10-01 19:37
    Franklin,
    Thanks so much for the source on the DIP30S sockets. I had a difficult time finding them. I will probably order some (5 min) this week.
    I have a couple of other projects going on too so I will have to multi-task myself as I can.
    Thanks again!
    edited 2007-10-01 20:31
    T&E Engineer
    When you order them you have to order $25.00 or more or·else·there is a $5.00 add charges for orders under $25.00 but you do not see this until you check out
    So i order 5 of the· DIP30S sockets
    ·And 2 ic Chips from them as well
    Sam
    edited 2007-10-03 21:29
    T&E Engineer
    They are out of stock·on the·DIP30S sockets and could not tell me when they will get them in but they said that they will email when they get them in
    Sam
  • kelvin jameskelvin james Posts: 531
    edited 2007-10-04 06:04
    Try this for the socket, they may have others that are cheaper.
    www.digikey.com/scripts/us/dksus.dll?Detail?name=ED90224-ND
    edited 2007-10-04 21:12
    kelvin james
    Thanks for the Link
    I did not know that they carry them
    Sam
  • David H.David H. Posts: 78
    edited 2007-10-08 19:01
    I was reading your listings, and all I found for you were sockets that might work for you. All it would help is allow you to replace the chip in your adapter.
    Part numbers at Digi-Key are ED22304-ND & ED90224-ND. They are 30 position at a .07" pitch, and the rows are .4" apart. If you are still looking, hope this helps.
    Mr.Clyde
    David
    There are 10 types of people in this world,...
    Those that understand binary numbers, and those that don't!!!
