Question about the PING))) water test
I read this article with great interest as my main hobby is aquariums. However, I want to make sure of something. Did the PING give the depth of the water or the distance from the surface of the water?
If its the latter, I have use for it as a accurate evaporation controller. I'm willing to risk the humidity damage.
If you know the distance from the PING))) to the top of the water in the tank/vertical tube, and using simple math, you can determine the level or amount of water in the tank/tube..
I use the PING))) device inside a 4 inch PVC pipe which is remotely located and at the exact same level as my water tank on my boat to display on an LCD the amount of water (gallons) left in the tank.
Deno
Post Edited (deno) : 9/8/2007 11:22:24 AM GMT
Post Edited (MarkS) : 9/8/2007 6:14:09 PM GMT
Gr,
Mightor
| To know recursion, you must first know recursion.
| I'm afraid I might be phobophobic.
Mounting the PING))) above the fish tank a couple of feet or in a sump that is tied to the tank and seeks the same level as the water in the tank will work.· If using a sump, don't use anything smaller then 4 inches ID.· I know this to be true, as I did alot of expermenting sounding thru various sizes of PVC pipe.· I am successfully sounding a water level up to 42 inches deep in a 4 inch ID PVC pipe with the PING))) device mounted on top of the pipe.· Sounding pipe needs to be near vertical in position.
I also cut large 2 inch diameter holes (using a hole saw) on opposite sides of the vertical pipe, just below the PING))) sensor for air to circulate around the PING))) device to avoid condinsation on the device.·The PING)) device does not see these holes.·In my case the actual water level in the tube never gets closer then 12 inches to the PING))).· I am suspending the PING))) inside a 4 inch PVC cap that sits on top of the pipe.· ( Cap not glued to pipe.)
Again, repeating, using the PING))) thru a Stamp, you can very accurally determine when you need to add water to the tank using some sort of electric water valve.·
Hope this helps...Deno
I still need an answer to my question here:
