Basic Stamp OEM Minimums
I am fairly new to the Basic Stamp but fairly familiar with electronis.· I have been playing with the basic stamp and its programming for a circuit that I am building.· I am looking to install the OEM style of the Stamp with only the minimums because I will not need to hook a computer to it once the chip is installed.· Could someone please look at the attached file and tell me if they think it will work.· I can build this circuit for almost $14 a piece vs $49 a piece for the whole stamp package.
Also, I have ordered a serial LCD display to add to his project.· Does that just connect to one of the Data pins such as "P15" or does that connect to the Serial Out pin.· If it does connect to the serial out pin what other components if any would I need between the PIC chip and the LCD display.
Attached is a drawing of what I intend to build.· It was modeled off of the one available from Parallax which can be seen at http://www.parallax.com/dl/docs/prod/schem/bs2oem.pdf·.
Please give me your input as to if this circuit will work or not.· Thanks!· James
- Rick
A Stamp is essentially the pre-programmed PIC chip, an EEPROM, a resonator and a few resistors.· All the other components are for the Reset circuit, the Voltage Regulator Circuit, and the Programming Interface Circuit.
Starting with either of these pre-programmed chips and assembling your own Stamp is one of the easiest and more economical ways to get involved in micro-controller programming you will find.
- Rick
Also, please do not think that I am getting information and drawings from Parallax and buying my parts elsewhere for cheaper. I do buy a fair ammount of compents from Parallax. Acturally for this project I am intending to buy a few homework OEM boards to use as the programmer and several serial LCD displays directly from Parallax.
- Rick
