BS2 and Vss. — Parallax Forums
BS2 and Vss.
Willsworld.orgWillsworld.org Posts: 23
edited 2007-09-08 01:22 in BASIC Stamp
Are the mounting screw holes of the BS2·tied into Vss and can I use this attached to my frame as the grounding/negative·bus tied to my batteries negative pole?
  • Larry SutherlandLarry Sutherland Posts: 77
    edited 2007-09-07 22:58
    Continuity test can verify. Intentionaly grounding to frame, I don't recommend especially if system controls voltages from other separately derived electrcial systems.
  • Steph LindsaySteph Lindsay Posts: 767
    edited 2007-09-08 00:14
    Q1) Are the mounting screw holes tied to Vss...
    A1) Yes, the plated holes at the corners of the Board of Education are connected to Vss.· The Boe-Bot Robot makes use of this with the Tactile Whisker Navigation project - see book page 171 in Robotics with the Boe-Bot.
    Q2) ...and can I use this attached to my frame as the grounding/negative·bus tied to my batteries negative pole?
    A2)·This is not my area, but I would take·Larry Sutherland's advice.· You may be setting yourself up for ground loops.
    -Stephanie Lindsay
    Editor, Parallax Inc.
  • Willsworld.orgWillsworld.org Posts: 23
    Thank you guys, I have a rather complex robot with 7 IR sensors, 3 motors, 3 controllers, and hopefully an RF transceiver system. Lots of Vdd and Vss conductors, I'm hoping I can reduce some of the wiring by creating a frame Vss bus. I am running all systems (motors and BOE) from a 24v system. And yes, I have split the 2-12v series batteries to run the BOE. I'll have a picture of the robot (still working on it) on my web site tomorrow. Check it out if you get a chance. www.willsworld.org
    Once again, thanks.
