Divide by 10
In the September issue if Nuts & Volts there was an article on floating point math on a 8-bit·chip.· Using what the author outlined I came up with a simple routine to divide a byte by 10 and determine the remainder.· This routine only involves simple shift and add instructions. In the following code X is the byte that will be divided by 10, tmp1 and tmp2 are just temporary variables. The "Result" contains the answer to the division.
tmp1 = X>>2
tmp1 = tmp1 + X
tmp2 = tmp1>>1
tmp2 = tmp2 + X
Result= tmp2>>4
tmp1 = Result<<2
tmp1 = tmp1 + Result
tmp2 = tmp1 << 1
Remainder = X - tmp2
I have used this routine in a couple of my SX programs and it seems to work fine.
tmp1 = X>>2
tmp1 = tmp1 + X
tmp2 = tmp1>>1
tmp2 = tmp2 + X
Result= tmp2>>4
tmp1 = Result<<2
tmp2 = tmp1 << 1
Here is what I suggest for a fast divide by 10 with remainder:
' Byte divide by 10 with remainder DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX FREQ 4_000_000 x VAR BYTE result VAR BYTE remainder VAR BYTE PROGRAM Start NOSTARTUP Start: x = 0 ASM 'Divide by 10 MOV remainder,x CLR result MOV W,#160 SUB remainder,W RL result SB result.0 ADD remainder,W MOV W,#80 SUB remainder,W RL result SB result.0 ADD remainder,W MOV W,#40 SUB remainder,W RL result SB result.0 ADD remainder,W MOV W,#20 SUB remainder,W RL result SB result.0 ADD remainder,W MOV W,#10 SUB remainder,W RL result SB result.0 ADD remainder,W ENDASM 'result = x / 10 'remainder = x // 10 END
This is basicly and "unrolled" version of the normal division code.
Bean
The first rule to being successful is "Learn from your mistakes",
The second rule is "Be willing to make mistakes"
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 9/9/2007 1:05:31 PM GMT
