I've been successfully sending email from three different PINK modules, 2 running firmware v 1.0 and 1 running firmware v 1.1, through two different ISP mail systems (with and with out "authentication").
If you are still having problems with sending email from a PINK module could you post a code snippet that shows how you are setting up the variables to send the mail, etc. and I should be able to give you a hand.
As I remember you can also test sending email directly from the PINK module itself directly through the variable page (http://<PINK name or IP address>/pageVV_Show.htm) at least in PINK firmware v 1.1. I can't remember off the top of my head if you can do this in firmware version v 1.0 (my PINKs are at my observatory but I will check this weekend)
Frank
