Propeller Map Display
I wish to use propeller to display a map with appropriate resolution. Is there an easier way than hand coding the vga display ? The idea is to generate a moving map with gps with a prop replacing a PC.
Thank You
Chris
Thank You
Chris
Post Edited (mcstar) : 9/6/2007 7:49:33 PM GMT
The processing power of the Prop is absolutely sufficient to do it. A highly optimized net of geo-referenced streets of a major town fits into 1 MB (we used PCMCI cards as memory (now called PC-cards))
Optimal coding and decoding however is tricky....
Thanks for the responses
Chris
