PING))) Sensor angle problem...
I'm considering using the PING))) Sensor as a range finder to track the progress of a metal ball (1" diameter) for a school project. The distance I'd be working with would be within 2'. Does anyone have any experience with the PING))). Or perhaps a better suggestion for a range finder?? Thanx!
Your subject mentions an Angle Problem, but your message says nothing about this. A metal ball will inherently reflect no matter which way it is moving. Take care.
That would depend on a lot of factors. You may have to test the setup to see if there is anything which is more likely to reflect a signal than the ball. This will depend on material composition, facing or perpendicular surfaces, etc. Take care.
I think your best bet would be a Sharp GP2D12 Infrared Object Sensor if the height of the ball in relation to the robot is consistant.· It has a 2-3 mm beam and works within the range you mentioned.
Daryl
