Surge/over voltage protection — Parallax Forums
SiriSiri Posts: 220
edited 2007-09-07 15:02 in BASIC Stamp
I am planning to connect a solid state relay(SSR) 12V input and 120 VAC load to my project(BS2px based) to switch a 110VAC motor.
·- ·AC motor rated at 110VAC· 60Htz- 0.55Amps.
The·application notes·from the SSR manufacturer·requires the addition of·"overload protection" as overload protection is not built-in to the SSR.
Is connecting a disk varistor in paralled with the AC·terminals of the SSR is·sufficient ? - ·if so please suggest values for the varistor or other easy way to solve this.
Thank you.
Siri
    edited 2007-09-06 21:27
    Siri
    Please give us a web page link to solid state relay(SSR) 12V input and 120 VAC
    That you are going to use
    What this mean is that this device dose not have a fuse built in· so you will need to put a fuse>>>>>>>for what the rating of the solid state relay is
    ·Surge/over voltage
    I would put one on the power·going to the·SSR and one after the SSR
    going to the motor·
    I hope that help you in some way· ·
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Post Edited (sam_sam_sam) : 9/6/2007 9:40:17 PM GMT
  • SiriSiri Posts: 220
    edited 2007-09-06 23:51
    Sam,
    I am attaching the manufactureres data sheet.
    Thanks for your help.
    Siri
    edited 2007-09-07 01:59
    Siri
    After reading the data sheet i would say that do what i put on the frist post
    This is what i would do if i where doing this project smile.gif·the reason that i am·saying this is that i have a pool pump
    that i am going to put on a 25 amp SSR the runnig amp are 10 amps but stalled is 21 amps now i do not want
    this to last more than 3 seconds i will use a fast acting fuse rated at 20 amps so that if for some reason this pump is
    jamped it will not have any power to it and burn out the SSR this cost $45.00 for this SSR and a fuse $2.00
    I can replace alot of fuses before i get to $45.00· This SSR has a built in heat sink
    What happen was one day when i came home from work··I heard the pump humming and not running
    and the pump was very very warm not so hot that you could not touch it yet
    but·i was able to fix what was wrong with this motor now is all well right now
    ·I am just using a relay
    What I going to do is put a (current sensor This was not cheep $100.00)·on this pump and when the amps are more than 10 amp
    I will also add a routine to the pool pump timer routine that will LOCK OUT the PUMP and will flash a LED that will tell me that something wrong with the pump
    I would get the 8 amp verson and put a fuse that will handle the inrush current that if you plan on turn the motor
    ON and Off alot in a short time frame·the fuse should blow in·5 seconds when the is stalled
    You are rating the fuse for the motor not for the SSR
    The reason for this that when you run a motor for lot of short burst the motor will run hotter
    If this not the case then you maybe·able to·just use a fuse that would blow if the motor was
    stalled and not running for let say 10 second the should blow when the motor is stalled
    Sam
    Post Edited (sam_sam_sam) : 9/7/2007 2:09:38 AM GMT
    Sam,
    ·Thank you very much for all the help will try what you suggested.
    Siri
