Need suggestion for TFT LCD interface.
I have been tearing apart the Spin examples from the site and am learning a lot pretty quickly. I have some code that Ive been messing with for a few days and getting some pretty exciting things from the 2.5" Parallax TFT LCD screen through the TV.spin object. I need to find a 1.5" to 1.8" screen that I can mount in my own case. There are plenty out there but im unsure of the interface to get because most of them do not take composite video. I am new to the video stuff and dont really know what to get. Do these things use serial natively or is it something different all together. Do they use VGA meaning I have to re-write my code? I'd like to get more colorful with the display and should have the Hydra book tomorrow, so hopefully that helps. Any suggestions?
Thanks!
Jason
Thanks!
Jason
MPU interface mode: 8080/8-bit
LCD controller: HX8310 or equivalent
Interface: parallel 8080 or 8088
LCD controller: NT7525
The reference to 8080 and 8088 will say that you have to simulate the bus protocol for that processors, which is not difficult, but is not what the video logic of the propeller generates.
You need not only 8 data bits but also 3 control lines and most likely 10 to 12 address lines, assuming those displays contain an own video memory. This all can of course be done by simple OUTA instructions....
Post Edited (deSilva) : 9/6/2007 5:59:58 PM GMT
But some things can be accomplished more easily than others
I can assure you that if you want to accomplish the same multifunctional project using a eg ARM7/9 core you easly get a very complex system. The power consumption will be 5 to 10 times higher than the propeller (6mA average / cog )
If the engineers increments the amount of memory in the future the propeller chip can break through in many applications.
Indeed also me i'm new in this and I quickly had a great feeling in playing with the existing good driver code this also speed up the development of new object hugely. You take an object compile it and of you go. this can't be always said of other core architectures in respect to community exchanges !
The cream on the cake is it's all for free ! A special thanks to the people who build wonderfull object ready to use out of the box.
PS
I'm NOT a PR agent of Parallax
Cheers
Guy
