Sending Email From PINK
Another problem with PINK that I forgot to mention (besides my #1 problem·below, posted before)·is
that I can not send an email as advertised.· This problem should be independent from my other problem.······
From the default web page, I should·be able to set all related variables (FROM, TO, SUBJECT, SMPT·SERVER, etc) and hit the test button provided in the web page, but it does not work.·· Maybe because there is no variable to enter the password to the SMPT server???
·· I bought this PINK just for this feature and it does not work, I'm even paying·extra for a POP account, so that I can use an SMPT server to send and receive.
I have everything set according to documentation.· But I can read or write from/to the PINK!!
The bS2 is working fine. and I can set the PINK from the default website. I have checked the jumper, the baud rate the code, etc.· I know there is no communication between the two because there is no activity on the Telnet application for monitoring, I don't get anuthing back from debug window and I can verify from the website that no variable was changed.· What should I do to troubleshoot this before I send it back?
