Can not communicate between bs2 and pink
·I have everything set according to documentation.· But I can read or write from/to the PINK!!
The bS2 is working fine. and I can set the PINK from the default website. I have checked the jumper, the baud rate the code, etc.· I know there is no communication between the two because there is no activity on the Telnet application for monitoring, I don't get anuthing back from debug window and I can verify from the website that no variable was changed.· What should I do to troubleshoot this before I send it back?
I think I told you that I already tried different baud rates, like the one used in the PINK documentation, 396. So even using anything below 2400 does not work. If this is a bad unit, just tell me and send me another one!!
We are going in circles, and you keep suggesting the same things....!
Looking at your previous message I see no indications of baud rate values used. My suggestion was to make sure the baud rate was set to 2400 bps in both the IPSETUP as well as the Configuration Web Page. Has this been done?
