Counter Weight for BOE Bot Gripper kit — Parallax Forums
Mike NJMike NJ Posts: 20
edited 2007-09-04 21:30 in Robotics
In the description for Parallax· # 28202 Gripper Kit
[*]Lift up to 4 ounces (113 grams) without counterweight [*]Lift up to 14 ounces (397 grams) with counterweight (not included)
· Where is this Counter weight located on the web site, and how much is it??
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-09-04 18:40
    I think they might mean that you need to put extra (counter)weight on the BoE-Bot, otherwise it will just pull it's nose down instead of picking the load up.
    - Rick
  • D FaustD Faust Posts: 608
    edited 2007-09-04 19:04
    I don't think parallax makes them. YOU have to.
    LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
    LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
    ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
    END
  • WhitWhit Posts: 4,191
    I had a look, and I don't see that they sell one.
    Whit+
  • Steph LindsaySteph Lindsay Posts: 767
    The gang is correct here - there is no counterweight available from Parallax, hence "not included" instead of "sold separately" in the docs. I was assuming folks would use miscellaneous objects for counterweights as needed, such as a roll of coins or fishing weights.
    -Stephanie Lindsay
    Editor, Parallax Inc.
