Hardware Communication Error
Well,
·· I am not having much luck with this one, Its a home grown BS1 OEM, I have built several of these without a problem. It will identify without any trouble tho. I have Checked / Cleaned all of the connections from the PC, to the chip. I have re-heated all of the solder joints , and verified all connections on the board. I started having this error, on the last chipset that I built, but cleaning the header pins solved it. I wonder.........maybe the BS1-serial adapter may be the cause, tho I have not let any smoke out of it (we all know that anything electronic runs on tiny amounts of smoke stored inside).
·Has anyone else ever had this problem? I guess I'll go build another and see ifn itll work.
········· "Hardware Communication Error, Check serial Cable and Power Supply"
ETERNAL NOOB, you could learn alot from a dummy.......
"one should not profess ones ignorance, one should just read more books"
······························································ ......unknown
Dave
Dave Andreae
Parallax Tech Support·
I have had both of these problems in the past.
Is it possible to try another computer?
