Line Follower App Kit code error
Hello,
I am new to robotics and just purchased the QTI line Follower AppKit for the Boe-Bot (#28108) the source code that came with it generates the following error message:
·Error 129 - Expected ':" or End-of-Line. This message occurs when the program gets to the "qti" text immediatly after the SELECT text. I have included the program below and colored the text red where the problem seems to occur. Can you help???
Mr Dan
Las Vegas, Nevada
'QtilineFollw.bs2
'Boe-Bot follows electrical tape with 3 QTI modules
'{$STAMP BS2}
'{PBASIC 2.5}
qti VAR Nib
Do
Right: HIGH 5: Pause 1: qti.BIT0 = IN3: INPUT 5
Center: HIGH 6: Pause 1: qti.BIT1 = IN3: INPUT 6
Left: HIGH 7: Pause 1: qti.BIT2 = IN3: INPUT 7
SELECT qti
CASE %010 'Forward
PULSOUT 13, 850
PULSOUT 12, 650
CASE %011 'Pivot right
PULSOUT 13, 850
PULSOUT 12, 750
CASE %001 'Rotate right
PULSOUT 13, 850
PULSOUT 12, 850
CASE %110 'Pivot Left
PULSOUT 13, 750
PULSOUT 12, 650
CASE %100 'Rotate Left
PULSOUT 13, 650
PULSOUT 12, 650
ENDSELECT
PAUSE 20
Loop
Mr Dan
Las Vegas, Nevada
'QtilineFollw.bs2
'{$STAMP BS2}
'{PBASIC 2.5}
qti VAR Nib
Do
SELECT qti
CASE %010 'Forward
PULSOUT 13, 850
PULSOUT 12, 650
PULSOUT 13, 850
PULSOUT 12, 750
PULSOUT 13, 850
PULSOUT 12, 850
PULSOUT 13, 750
PULSOUT 12, 650
PULSOUT 13, 650
PULSOUT 12, 650
ENDSELECT
PAUSE 20
Loop
bs2
703B
it appears that the
'{PBASIC 2.5}should be
'{$PBASIC 2.5}▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
I'm new to the propeller!
