C++ Exception — Parallax Forums
C++ Exception
EnriqueEnrique Posts: 90
edited 2007-09-05 10:25 in General Discussion
When compiling the following program the IDE gives a C++ Exception
// test variable locality
import stamp.core.*;
public class Locality{
· static LocalVariables here = new LocalVariables(20);
· static void main(){
class LocalVariables{
· void LocalVariables(int argument){
··· argument=argument;
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2007-09-03 18:44
    Please attach the classes exactly as they are.
    regards peter
  • EnriqueEnrique Posts: 90
    edited 2007-09-03 18:51
    Peter,
    The source code you see is all there is to it.
    I just discovered that the program has a syntax error, the constructor has a void keyword that shouldn't be there. When I remove the void it compiles without problems.
    edited 2007-09-03 19:19
    I still like to have the class that generates the error as an attachement.
    That way I am sure I have the exact file to reproduce the error so
    I can fix the C++ exception.
    regards peter
    edited 2007-09-05 09:13
    Let me know if you need any aditional information
    Thanks for the file.
    The error source is the 'void' instead of 'public' for class LocalVariables.
    On my system, Jikes aborts and I must 3 times click 'don't send rapport'
    before the C++ exception appears. This exception appears both
    in release 2.0.3 IDE as in the beta IDE.
    I will see if I can prohibit the C++ exception, preferable with a message.
    There is nothing I can do about Jikes, so the abort windows will
    keep popping up for such syntax errors. So perhaps it is best to simply
    prohibit the C++ exception window to popup as well. There really is no
    point in having a message stating Jikes aborted, as that is already clear.
    regards peter
