how do i hook up a 5V LDO Voltage Regulator — Parallax Forums
jaspittmanjaspittman Posts: 22
edited 2007-09-04 14:07 in General Discussion
the tab on the top is ground does that mean i have to tie it to ground or can i leave it unconnected
    edited 2007-09-03 17:31
    It is electrically the same as the middle pin -- it doesn't have to be "connected" (too), but bear in mind that it is still GND.
  • pwillardpwillard Posts: 321
    edited 2007-09-03 22:20
    ...and a heat sink
    There's nothing like a new idea and a warm soldering iron.
  • Blackbird455Blackbird455 Posts: 124
    edited 2007-09-04 01:07
    and dont forget those little capacitors to stabilize the input and output
    ETERNAL NOOB, you could learn alot from a dummy.......
    "one should not profess ones ignorance, one should just read more books"
    ······························································ ......unknown
  • crgwbrcrgwbr Posts: 614
    DEFINITELY don't forget the caps that Blackbird455 mentioned. On one board I designed, I thought I'd try powering it on before I soldered them in place. Long story short, 10.5v went strait into VDD on a propeller (7.2 volts too high).
    My Blog: Prog | Electro | Mech
    I would love to change the world, but they won't give me the source code
    People say that if you play Microsoft CD's backwards, you hear satanic things, but that's nothing, because if you play them forwards, they install Windows.
    I spent a minute looking at my own code by accident. I was thinking "What the heck is this guy doing?"
