Wiring a Serial PC Connection problem
Chengmania
Hello everyone,
I have placed my BS2 Module on a Breadboard and I have soldered together a 9 Position Female D-Sub Connector according to the wiring diagram in the Stamp Manual. I plugged everything in the appropriate position on the BS2, powered everything up, and the Editor won't Identify the BS2.
The diagram I'm using is on page 28 of Basic Stamp Syntax and Ref Man v2.2
IS there anything I can check?
Any help would be awesome. Thanks
~Greg
~Greg
If you go to www.amazon.com and search for this book, the Search Inside feature enabled, so you may be able to glean more information for free. But it's a worthwhile book to purchase if you're going to be doing serial comms!
Thanks again.
You should post a new topic.
Sorry.
The direct answer to your question is - no, it can not be disabled, but please note the following.
That echo effect is only seen when one uses Pin Port 16, so if you use some other Pin Port, the problem will disappear. If necessary, use a MAX-232 (or equivalent) to restore the higher voltage levels used in RS-232 communications, on that "other" Pin Port.
Bruce Bates
Post Edited (Bruce Bates) : 9/11/2007 8:52:01 AM GMT
