Basic Stamp Editor Messaage
Larry Sutherland
Does any body have an idea...Windows Vista
I'm using:· "·Basic Stamp Editor V.2.3.1", "Board of Education-Rev C" , and doing excersises in Capter 4 "Robotics with the Boe-Bot".·
A message appears:
A second message appears:
L Sutherland, Phoenix AZ
Post Edited (Larry Sutherland) : 9/3/2007 4:19:42 PM GMT
A message appears:
- Basic Stamp Editor_Access violation at address 00466AA8 in module 'stamp.exe.' Read of Address 00000004.
- Microsoft Window_A problem caused the program to stop working correctly.· Wndow will close the program and notify you if a solution is availabe. CLOSE PROGRAM
I have xp myself, and I haven't heard of any problems with vista, but hopefully a vista user who might have had the same problem will speak up.
now I keep my normal use of my xp system under a limited user account. which makes me log onto my xp admin account when I want to install most programs. I don't know if your using an admin or limited account but you might want to find out what type of account your using (if you don't know).
you may even want to make sure you do a normal full shutdown (log off, then shutdown computer).
like I said I don't know yet the specifics of vista but with most microsoft operating systems this usually takes care of silly problems like you have.
unless it's a know problem, in which case someone else will have to help ya out, but try the above real quick.
I am the only Admin. to my computor.
Question_ Unplugging USB are there any percautions?
I have another "Board of Education, Rev C." that I'm using for "What's a Microcontroller" excercises so far so good
Post Edited (Larry Sutherland) : 9/3/2007 4:19:12 PM GMT
Otherwise, Windows is going to think that the USB serial device is still plugged in, and the interface code will fail with the errors you're seeing.
I don't know how this might apply to the Stamp's USB interface, so just apply it to "more information"...
Yes, this problem is caused by unplugging while the USB port is open. To avoid this problem, before you disconnect or·reconnect your board, or reprogram the BASIC Stamp, be sure to:
1) Close any open Debug Terminals
2) Turn off power to your board
We apologize if you received a Boe-Bot Robot Kit with a USB Board of Education that did not also include a separate document for your USB BOE. (The Robotics with the Boe-Bot text was written when only the serial version of the BOE was available in the robot kit.)
I hope you are otherwise enjoying your kit. If you have any other difficulties, please let us know.
-Stephanie Lindsay
Editor, Parallax Inc.
Now when I open up the stamp editorI make sure I'm in the 3.2.1 and the oher two versions uninstalled from computor.
I'll know here in a little bit.
I am interested in others thoughts on this possibilty.
Thank you
I know you are right because I was also making those mistakes too. Especialy leaving the Debug Terminal open!
Thank you
Larry Sutherland
-Stephanie
