Serial camera module
anyone know a more local (and less sketchy) source of these camera modules?: www.roundsolutions.com/cmos-camera/index.htm
anything similar would work, I just need a small, low power serial video camera.
- Stephen
I have one of these and use it with a Propeller and SD card. It works great for making a time lapse camera where you can control everything. The camera's documentation is kind of lacking and you have to send sync all the time to keep it from going to sleep. I may release example code sometime after I finish with my latest project (it involves ethernet, a propeller, and a camera).
Attached is an example image (the camera requires a lot of light). Make sure you get one with a IR cut filter or else it will get flooded by bright light (aka sun light).
Harrison
Post Edited (Harrison.) : 9/2/2007 5:17:47 AM GMT
Do you happen to know of any other modules that operate at a higher bitrate? something like 250kbps maybe? These are really the only digital output cameras I've seen out there besides the CMU-cam (and the module that it's based off).
Now for the fun part. Has anyone written a simple app that lets you at least get the preview video from the serial port? I'm going to start working with this thing tonight, but if theres any work done already I'd love to see it.
Thanks!
files.fwdweb.com/uploads/sdcamera-archive%5Bdate2007.09.08time17.58%5D.zip
