BS1 Firefly effect question
Hi I am using this code to make an effect and cannot for the life of me figure out how to make it work when I trigger pin 7, and only cycle for seconds then wait again until it it triggered. I have spent much time trying to make this work with no success. What would the code look like? The code I am usin is just below this paragraph. Thanks soo much!
[noparse][[/noparse] Variables ]
SYMBOL lottery = W1 ' random value
SYMBOL timer = W2
SYMBOL oldFlies = B6 ' flies that have lit
SYMBOL flyNum = B7
SYMBOL mask = B8
SYMBOL test = B9
SYMBOL idx = B10
SYMBOL lastFly = B11
[noparse][[/noparse] EEPROM Data ]
BitMask:
EEPROM (%000001, %000010, %000100, %001000, %010000, %100000)
[noparse][[/noparse] Initialization ]
Reset:
DIRS = %00111111 ' make P0-P5 outputs
lottery = 1031 ' seed random value
[noparse][[/noparse] Program Code ]
Main:
FOR idx = 1 TO 3 ' tumble random generator
RANDOM lottery
NEXT
flyNum = lottery // 6 ' select "fly" (0 to 5)
IF flyNum = lastFly THEN Main ' no repeats
lastFly = flyNum ' save current fly
READ flyNum, mask ' get its bit position
test = mask & oldFlies ' check in "oldFlies"
IF test > 0 THEN Main ' if not 0, already lit
GOSUB Fade_On ' activate fly
timer = lottery // 251 + 250 ' 250 - 500 ms delay
PAUSE timer
GOSUB Fade_Off ' deactivate
timer = lottery / 32 ' delay between flies
PAUSE timer
oldFlies = oldFlies | mask ' mark this fly
IF oldFlies <> %111111 THEN Main ' still more?
oldFlies = %000000 ' no, reset
GOTO Main
[noparse][[/noparse] Subroutines ]
Fade_On:
timer = lottery / 16 // 5 + 1 ' randomize brighten time
FOR idx = 0 TO 255 STEP 15 ' sweep from off to on
PWM flyNum, idx, timer ' brighten the output
NEXT
HIGH flyNum ' leave the output on
RETURN
Fade_Off:
timer = lottery / 32 // 5 + 1 ' randomize fade time
FOR idx = 255 TO 0 STEP -15
PWM flyNum, idx, timer ' dim the output
NEXT
LOW flyNum ' leave the output off
RETURN
SYMBOL timer = W2
SYMBOL flyNum = B7
SYMBOL mask = B8
SYMBOL test = B9
SYMBOL idx = B10
BitMask:
Reset:
Main:
RANDOM lottery
NEXT
PAUSE timer
PAUSE timer
GOTO Main
Fade_On:
NEXT
RETURN
Fade_Off:
NEXT
RETURN
new variable:
Symbol Countdown = B0
PreMain:
if PIN7=0 then PreMain
Countdown=30
Main:
..............rest of your·Main Code goes here
Countdown=Countdown-1
if Countdown=0 then PreMain
GOTO Main
... your subroutines go here
Have Fun
TR
There are examples on how to do a firefly simulation over onthe EFX-TEK forums here:
http://www.efx-tek.com/php/smf/index.php?topic=80.0
and here:
http://www.efx-tek.com/php/smf/index.php?topic=220.0
Source code for the BS1, schematics and even pictures are there. [noparse]:)[/noparse]
Vern
