need a touch switch
I have a disability that makes it difficult to activate different devices (as in pushing buttons, flipping switches), and am planning on using a microcontroller (basic stamp) to help activate these devices. That means they need to be touch activated. I am considering a few different options: the flexiforce pressure sensor, the QT113-D Touch Sensor, or the peizo vibra film tab. Which of these options would be the best?
Testing several different kinds of touch sensors wouldn't be a bad idea, it would certainly be a great learning excersise
regards
Jeff T.
http://www.parallax.com/detail.asp?product_id=604-00038
regards
Jeff T.
In the mean time connect your touch sensor and write a program to do what you want and test the outputs with a LED. When you get past that stage you can start to design the·switching elements of your project.
Jeff T.
Also, do I need to make all of the connections for the touch sensor shown in the schematic, or are some of them optional?
Thanks for your continued advice with this project. You have no idea how much you have helped me.
The power·for the servo is not taken from the Stamp regulator but from the supply to the regulator.
The Stamp is used to control the servo and can deal with it without problem.
Your supply to the servo needs to be 6-7 volts dc maximum·and be capable of supplying the current you require
The control for the servo is a pulsed 0-5 volts controlled from the BS1 module
Jeff T.
with the ground pins connected, input pins connected, and output pins connected.· Or you could try to find a different regulator with a higher current rating.
Jeff T.
