what gets hot?
Idle curiosity.
I am considering hot gluing a µSD adaptor to the top of the big Prop chip. I figure that there's actually just a small-ish part of the dip that needs to be·air cooled and I assume that it's in the middle. (Rest of solution: spot solder pre-tinned resistors to appropiate adaptor contacts, insert other ends of resistors into appropriate breadboard locations.)
Is there any reason I shouldn't put a hat on my prop?
Paul Baker
Of course if you use a thermal glue or sticky pad the socket may become a heat sink.
Graham
