Using ultra-bright LEDs
Hi All,
I'm working on·a project for a friend of mine. She wants a traffic light that is triggered by noise levels in her classroom. I have the sound detection circuit working, and am playng with tweaking that.
My question is in regards to ultra-bright LED's and driving them. I purchased a traffic light that uses regular light bulbs, and I want to convert it over to LEDs to save power and make it more reliable. My plan is to replace the bulbs with clusters of LEDS.
So, my questions are:
How many LEDs of whawattage will I need to make the lights visible easily in a brightly lit classroom?
I was thinking of using a MOSFET to drive them. Any reccomendations?
Any reccomendations where to purchase the LEDs? Im seeing maybe 7-12 per cluster.
I will be using a Stamp, so the MOFSETS must be driven with 5V.
Thanks!
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Thanks!
Jonathan
Tim
the luxeons make a ton more light for the dollar, and generally offer a 140 degree viewing angle, versus 15 to 30 degrees from a superbright.
The only thing that I would not recommend is driving the luxeons from 5 volts.........the amps and the heat will eat you up.....if you run the luxeons in a series of three, you can generally wind up @ 11.55v or 300mA, 700 mA, or even with the K2 bulbs 1500mA..........or if run off of a lm7805 regulator (5 volts)........ that would be one regulator per bulb, plus alot of heat dissipation per regulator. If the old light housing was run with a halogen bulb, I would assume that there is some type of reflector in place....that would mean that you could use just one luxeon K2 in the place of it, and it would be plenty bright. Are the lenses colored on the light housing? If they are then you could use a white K2 @ 1500mA , and just stick with a bank of 3 7805 regulators, and one 5.6 ohm 2 watt resistor. What is your supply voltage going to be? Well, whatever you use there is a solution, and I will be glad to help you with it.
ETERNAL NOOB, you could learn alot from a dummy
www.superbrightleds.com/BA9S6_specs.htm
Never give up when things go wrong.
Post Edited (StampNut2) : 8/29/2007 6:33:47 PM GMT
Also, not too long ago, I bought some Luxeon clusters mounted on aluminum of all three traffic signal colors at All Electronics and from Marlin P. Jones.· All Electronics still has these and they work very well at 12V.· You still might find the other colors elsewhere.
One of my favorite MOSFETs for driving relatively large arrays of LEDs from logic level is the FDP7030BL.
Chris I.
Thanks again, saves me a lot of time experimenting!
Jonathan
