_CLKMODE used with pll4x problems
I've been banging my head on this one for two days now.··· Thought it was solved months ago but I'm building a frugal mans prop-plug with the schematic with transistors.··
Using Pin 30 to transmit serial data I finally was able to get garbage on my teraterm, that was a giant leap.
The interesting part is that if·I use _CLKMODE·+ pll4x with a 20MHz crystal it puts garbage out.· but if the multiplier is left off and I just use 20MHZ it works well.··
The serial object is "FullDuplex" as far as I can tell it does all timing calcs by using this bit of code
· bit_ticks := clkfreq / baudrate
so why should it matter that the clkfreq is 80MHz instead of 20?· i thought I was giving the processor some head-room with the bump to 80MHz.··
Maybe I'm using _CLKMODE incorrectly?·· Hitting F8 tells me that clock mode, clock freq, and XIN freq are all what I expect to see, except that it doesn't work.
Here is my CON section
· _clkmode····· = XTAL3 + pll4x········ 'Leave pll4x·off and it works.·
· _xinfreq····· = 20_000_000
I'd rather have a bottle in front of me than a frontal labotomy
good call.·· I guess that's why all examples use the 5MHZ crystal as it allow one to get to 80 and anything in-between.··
thanks.
