Parity calculation — Parallax Forums
Parity calculation
Ken PetersonKen Peterson Posts: 806
edited 2007-08-29 20:30 in Propeller 1
Anybody know of a really efficient parity bit calculation routine in SPIN?· I have an application that needs ODD parity and I was wondering if there is a more elegant way than shifting and XORing.
The more I know, the more I know I don't know.· Is this what they call Wisdom?
    edited 2007-08-28 17:09
    The fastest way hands down is using assembly language, an AND of the value with $FFFF_FFFF and the C flag holds the parity, a single instruction parity operation. This efficient means of computing parity has no analog in Spin.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 8/28/2007 5:17:29 PM GMT
  • Ken PetersonKen Peterson Posts: 806
    edited 2007-08-28 17:29
    Oh well...the rest of my routine is in SPIN and I'm trying to avoid using another cog just for one operation.
    Thanks!
    edited 2007-08-28 18:09
    Well, shift and XOR but faster than one bit at a time... This is from Hacker's Delight
    PUB Parity(x)
      result :=  x ^ (x >> 1)
      result := result ^  (result >> 2)
      result := result ^ (result >> 4)
      result := result ^ (result >> 8)
      result := result ^ (result >> 16)
      result := result & 1    ' 1=odd, 0=even
    That might be compressible to one line using intermediate assignments
    Tracy Allen
    www.emesystems.com
    edited 2007-08-28 19:12
    Tracy,
    you beat me to it... (grin)
    PUB Parity(x)
      x ^= x >> 16  'if x equals a   LONG you can start here
      x ^= x >> 8   'if x equals a   WORD you can start here
      x ^= x >> 4   'if x equals a   BYTE you can start here
      x ^= x >> 2   'if x equals a NIBBLE you can start here
      x ^= x >> 1
      result := x & 1    ' 1=odd, 0=even
    In other words, if Ken is only using BYTE variables all he needs in his routine is...
    PUB Parity(x)
      x ^= x >> 4
      x ^= x >> 2
      x ^= x >> 1
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 8/28/2007 10:06:56 PM GMT
    edited 2007-08-28 21:10
    That's pretty cool. Thanks guys. I knew there had to be a quicker way than brute force. Yes, I'm only doing a byte at a time.
    I'm visualizing it. You have four XOR gates, feeding into two XOR gates, feeding into one XOR gate.
    or.... ((b7 ^ b6) ^ (b5 ^ b4)) ^ ((b3 ^ b2)^(b1 ^ b0))
    Ken
  • deSilvadeSilva Posts: 2,967
    edited 2007-08-28 21:42
    @Ken: Your formula shows that the result is correct, as XOR is an associative and commutative operation, so you can ommit ALL parentheses!
    However there is a "by product" of many more results, as always 32 bits are XORed. This a why the last &1 is needed.
    edited 2007-08-28 22:32
    How about this? I'm not confident with the assignment operators.
    PUB parity8(x) : p
      p := x
      p ^= (p >>= 1) ^ (p >>= 2) ^ (p >>= 4) & 1   ' 1=odd, 0=even
    Tracy Allen
    www.emesystems.com
    edited 2007-08-28 23:30
    @deSilva: The parentheses are for illustration purposes. If I had done a rotate/Xor method, then the parentheses can be left out. Just in case someone else is reading and they don't quite understand what happens.
    Thanks again, Gentlemen. It's nice to have some brainstorming going on [noparse]:)[/noparse]
    edited 2007-08-29 05:36
    Ken Peterson said...
    What I wanted to say - and it is not always easy as a furiner - is:
    (1) YOU gave the STRUCTURE of the process using the parentheses.
    (2) The XOR operation is associative and communicative, therefor you can ommit all parantheses
    (3) So it becomes obvious that the process is correct, as anyone can see.
    (4) You did not describe the process absolutely correctly, as there is more going on in the program than your formula shows.
    edited 2007-08-29 12:32
    I guess I did show things in the wrong order. Perhaps it's more like this:
    b0 := ((b7 ^ b3) ^ (b5 ^ b1)) ^ ((b2 ^ b6) ^ (b4 ^ b0))
    Like I said before, the parentheses were to show the order of computation. For instance, b7 ^ b3 in the first operation. I realize that each operation is calculating a full 32 bits, but we don't care what the result is for anything above b3 after the first XOR, or anything above b1 after the second XOR, or anything above b0 after the third XOR. Hence the "& 1" at the end - it just cleans up the result.
    Am I still missing something?
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-08-29 17:56
    Tracy Allen said...
    Looks like a tacit rave review of this book.
    edited 2007-08-29 18:08
    Right! So your first approach describes this program, which will also work:
    PUB Parity(x)
      x ^= x >> 1
      x ^= x >> 2
      x ^= x >> 4
      return (x & 1)    ' 1=odd, 0=even
    edited 2007-08-29 18:19
    Fred,
    Yes, this is the Amazon link to Hacker's Delight. All reviews give it 5 stars. I purchased it on a recommendation here, from Cliff Biffle.
    Tracy Allen
    www.emesystems.com
    Tracy,
    Alas that lob softball pitch for hoped for pithy paragraph was whiffed, but I did order it last night on the basis of the first reviewer's opinion of Donald Knuth. I am looking forward to curling up with it and the prop ide and reading it through. Just as soon as I get something other than led's to show a program is doing something. (Lazy much?)
    Fred
