using pins 30 and 31
the manual says these pins are free to use for other purposes after they've loaded the eeprom, but what prevents interference from the eeprom after booting? Are there any hidden traps in using these pins?
Cheers,
Mark
Cheers,
Mark
the EEprom is hardware addressable (3 bits worth) they are all tied to ground so as long as you don't request any data from that chip's addres it should be silent. you could put other EEPROMs on the same bus as long as they had different addresses as set by the 3 external pins.
necessity is a mother
They form a pair of I2C lines and you should not apply signals to them the EEPROM could mistake for a correctly addressed access.
Paul Baker
Paul Baker
Brian
uController.com - home of SpinStudio
I'd rather have a bottle in front of me than a frontal labotomy
