Voltage follower output
Hello, I have one of the BS2 pins going to 5V and this is being fed into a voltage follower (opamp = LM358N) that came with the digital input/output kit.· The output of the follower is 3.7V with the 5V input?·This appears to be an upper limit as I have a A to D and D to A converter working that will output·0 to 5V depending on the setting of a pot.· The D to A functions well (0 to 5V is output with full scale input on the pot) but when this is fed into the voltage follower the output tracks the input upto 3.7V and then rails at this level?· Does anyone know if this is a limitation of the op-amp or does it sound more like something else.
thanks much
Boyd
thanks much
Boyd
...all the way at the bottom of the page.
Have Fun
TR
If you want full 0-Vcc input/output from an op-amp, one of the newer CMOS "rail-to-rail" chips (e.g. Microchip MCP6022) could be your answer. But be aware that the current drive capability at either extreme of its output range will be limited due to a lack of voltage "headroom".
Post Edited (Phil Pilgrim (PhiPi)) : 8/28/2007 2:34:00 AM GMT
boyd
