Question about the QFN package.
I guess that this is more general than Prop specific, but I've never used a QFN chip before. Is the center pad to hold the chip in place? If it has a more specific use, should it be left floating or routed to ground/Vcc? If it does not serve a purpose, can it be left off of the board? It takes up quite a bit of valuable routing space under the chip.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Paul Baker
Yeah, the QFP would probably be better. I'm not saving much more board space with the QFN and its definitely more complicated.
Thanks for the info everyone.
