Hi- questions about desiging a new robot to help play trumpet.
Hi, I'm a high school student who just started working with robotics. I have a friend who was recently paralyzed, and can only move his hands a little bit. He used to play trumpet, and can still blow, but has no way of holding the trumpet up and pressing the keys. Therefor, I want to create something that will press the keys for him at the slight movement of his hands (which won't be on the trumpet). Do any of you have any suggestions of what type of robotics kit to use, or what types of parts may work? I am really new to this and have little experience. Thank you.
Can he push buttons with his fingers ?
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
-Oz
How about an optical button? You could shine light diagnally at a set of 3 photoresitors and if your friends finger was covering the photoresistor (no force required) a stamp (or other processor) would send the signal to the solenoid to depress the trumpet thing. Do trumpets use partial depression or is it just up or down. It would take a little calibration to get it right if partial depression was the case.
What is important is that the position of the trumpet is somewhat flexible so that the "connection" between mouth
and the mouth-piece (embouchure) can be optimized by the trumpet player by means of moving his head / neck.
Ed
I remember Nintendo had one years and years ago, here's what it looked like: www.vidgame.net/NINTENDO/powerglove.html. Perhaps you could modify something like that.
Gr,
Mightor
| To know recursion, you must first know recursion.
A simple wooden mock-up should be easy to construct to test the concept and the circuit/code to trigger the solenoids should be pretty simple.
EDIT: Replaced PDF with JPG image.
Good luck to you and your friend,
Steve
I did some more thinking and some experimentation with a wooden block with cut-outs. See Rev 2 below. You get much better tactile feedback on your fingertips when you break the beam of each "valve" pair of sensors with this setup. If you experiment with the cut-out width (open to closed distance), you could provide tactile feedback for both open and closed "valve" positions. I don't know how much grip strength your friend has, but the thumb hole makes it much easier to hold and it feels more secure in your hand. It kind of reminds you of "brass knuckles" when you have it in your hand.
The mock-up that I did was just wood. This could be made very light and compact by using something like expanded PVC or some other kind of easily machineable plastic material.
PS - I've seen posts from several people on this forum who are magicians with a CNC cutter and expanded PVC and the like.
Post Edited (Duffer) : 8/25/2007 3:31:24 AM GMT
humanoido
ed
www.youtube.com/watch?v=L5akbOKGSFM
You might want to browse around after this vid plays
as there's numerous variations and performances.
humanoido
