Ping))) Crawler question. — Parallax Forums
walice_drelwalice_drel Posts: 81
edited 2007-08-24 02:04 in Robotics
Will the ping sensor kit work properly on a boe-bot with a the crawler kit installed on it? With the legs on it the boe-bot warbles around quite a bit. Will this effect the senor readings?
    edited 2007-08-23 14:58
    Readings will be erratic at best, but placement will make a bigger difference. It may or may not be able to see the legs. What you could do is run one and display the results while the bot is moving and see how it affects your readings. Only one person that I know of ever mentioned anything and he got erratic readings, however that could have been placement as well. Take care.
  • walice_drelwalice_drel Posts: 81
    edited 2007-08-23 22:37
    I just ordered the ping kit with the servo and brackets and the crawler kit. I should be here wed. Hopefully they will work together. If it does I will post a pic of it. It should look prety cool...lol
  • WhitWhit Posts: 4,194
    edited 2007-08-24 01:31
    It might look cool to take a few steps, stop and ping))) around, and then take off again. That would surely work without any problems and would look more bug like too.
    I guess it might be possible to time the ping))) to a set leg placement (same height, same position, etc) to standardize the readings.
    Whit+
    That is a great idea! I think im gonna give that a try when the parts get here wednsday.
