uOLED has arrived!
http://www.parallax.com/index.asp
for implementation see the Duffer: http://forums.parallax.com/forums/default.aspx?f=25&p=1&m=206948
That little sucker is a bit co$tly. Should adapt to some designs very well. Wish that price was for about 4x that area, though. OLED prices should come down some in time.
Downloaded the .pdf manual; lots going on with it and does have a µSD slot included. Neat they also have a USB to display i/f.
Now, if I didn't have projects to deal with.......
Harley Shanko
If you want something cheap, 4D Systems·also·makes a uLCD-128x128 (display only) that retails for about USD $20 (see below). You'll probably also want to get a breakout board for it (unless you want to build you own) $24 (also below). And you'll·need the Hitachi HD66766 datasheet for the display (attached - 100 pages) to sort out the register based (poke) interface. You'll need about 10 free I/O pins to interface to the display/breakout board. If you decide to go this route, please let me know how you make out. I look forward to seeing the results.
Steve
Post Edited (Duffer) : 8/23/2007 12:22:13 AM GMT
